2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
10 Speed Transmission in the Super Duty
  #136
Old 01-23-2017, 07:44 PM
Stalwart's Avatar
Stalwart
Stalwart is offline
With such a broad and flat torque curve there is really not much benefit to more gears. The only vehicles I've driven that effectively fallen outside of their torque peak were 2 stroke Detroit Diesels, especially when mated to automatics with 4-5 gears. Do we really need the complexity and how are all those smaller parts going to hold up to the torque?
  #137
Old 01-23-2017, 10:14 PM
BII Plow Truck's Avatar
BII Plow Truck
BII Plow Truck is offline
I'd love a Direct Shift gearbox (DSG) like in German cars. No automatic is like it, no slipping, and better mileage than any torque converter trans, and no manual stick shift can out-shift it! Waiting Ford......
  #138
Old 01-24-2017, 11:37 AM
kry226's Avatar
kry226
kry226 is offline
Originally Posted by workingdan
I agree, i see the 6.2 going away
Why? With 10 gears, the 6.2 will work even more effectively.
  #139
Old 01-24-2017, 03:24 PM
mjf6175's Avatar
mjf6175
mjf6175 is offline
Agree with this...in fact let me put my fireproof undies on so I can throw out some "heresy".
All the talk about the 10 speed in this thread up until now relates to it being teamed up with the diesel. Maybe the 10 speed will only be for a GAS engine in an HD? And what gas engine you ask? Look no further than the V6 in the new Raptor which has 450HP and 510ft/lbs. Now I am not saying this is better than having a diesel, but those figures sure do beat the V10 and the 6.2L. In fact Ford could dial the Raptor V6 back a little (425HP with 475ft/lbs) to gain reliability and better gas mileage and put the 10 speed behind it like it already is going to do in the Raptor. Just a random thought.........
  #140
Old 01-24-2017, 03:48 PM
workingdan's Avatar
workingdan
workingdan is offline
It would but the times are a changing. I don't know about a V6 in a super duty. Seems to small but that is the way ford is going. Smaller V8 eco boost would be sweet.
  #141
Old 01-24-2017, 05:34 PM
johndeerefarmer's Avatar
johndeerefarmer
johndeerefarmer is offline
I would have to lock out several of the gears while towing heavy as I hate a truck that downshifts all of the time. A 10 speed is also more costly and more complex. Having said that if it could have a triple overdrive it could eek out a little better highway fuel economy
The 5.0 with a twin turbo and 10 speed would be a good option for those that can't justify the diesel
  #142
Old 01-24-2017, 05:45 PM
YouDon'tKnowMe's Avatar
YouDon'tKnowMe
YouDon'tKnowMe is offline
Ford did trademark the term Eco Beast and still haven't put it to use so maybe the new 4.8 V8 whenever that comes out could find some turbos....
  #143
Old 01-24-2017, 05:55 PM
johndeerefarmer
It's being used.
Ford is stating that this 2017 Ford Raptor EcoBeast is delivering more of everything (except cylinders). The horsepower and torque rating is 450 hp at 5000 rpm and 510 lb-ft 3500 rpm of torque with a V6!
  #144
Old 01-24-2017, 07:12 PM
YouDon'tKnowMe
Originally Posted by johndeerefarmer
It's being used.
I did not know that and am now severely disappointed....
  #145
Old 01-24-2017, 07:36 PM
rocket_scientist's Avatar
rocket_scientist
rocket_scientist is offline
Could not disagree with this more. The DSG can take up to 1.1 seconds to engage depending on conditions and it sucks. Though the new TDIs with the manual suck where if you bog it 50 rpm below idle it just cuts the engine power. Buyback can't happen soon enough for mine. (Wife has a DSG-TDI and wish she'd let them buy it back, too.)
  #146
Old 01-25-2017, 07:24 AM
troverman's Avatar
troverman
troverman is offline
I agree. I think a 10-speed trans behind the Powerstroke would be a waste. Added cost and complexity for tiny additional economy gains.
  #147
Old 01-25-2017, 07:26 AM
troverman's Avatar
troverman
DSG's are better suited for sports cars. They roll back, they have abrupt engagements, and there are delays when they engage. They can absolutely snap off shifts faster than any other type of transmission, but they generally would never hold up to the kind of use a Super Duty would require. They are also more expensive.
  #148
Old 01-25-2017, 07:29 AM
troverman's Avatar
troverman
The Raptor engine will not be going in the Super Duty. The 6.2L is much cheaper to build, and it simply is a workhorse with much less likely to go wrong. The Raptor engine is pretty strung out to get those numbers. The work-a-day F-150 is more realistic - 375HP - but those turbos would be spooled much more often just moving the added bulk of an empty Super Duty around. The fuel economy would be horrific towing 10k around.
  #149
Old 01-25-2017, 07:40 AM
Tom's Avatar
Tom
Tom is online now
The broader the torque curve the less of a driving impact it would be. You'd definitely see greater efficiency though.
There's an RPM point for every load condition that provides greatest efficiency. Too many RPMs The closer you get to that point, the more efficient you are. More gears mean the transmission can stay closer to that point. More speeds doesn't mean less reliability though...by all accounts the 6R140 is substantially more reliable than the 4R100 of years ago.
  #150
Old 01-25-2017, 08:00 AM
troverman's Avatar
troverman
These diesels have so much torque they never really have to downshift much on hills. That's a very nice feature for a relaxing drive. Nevertheless, when you head up a steep hill, even unloaded, and the truck stays in 6th gear but the boost is running halfway on the gauge...that's when the most fuel is being injected. It would seem in the interest of economy if the trans knocked down a gear it would use less fuel?
Quick Reply: 10 Speed Transmission in the Super Duty
