Maximum weight on 2015 F-150 Tailgate.
Does anyone know what the maximum weight is that can be put on the tailgate? I am looking at buying a used golf cart (electric) and was hoping to load it onto the back of my truck...that is until I found out that a metal bodied golf cart with the batteries weighs a little over 1000 lbs. Any thoughts?
Me too. However, we have the 6-1/2' bed, so I can actually put up the tailgate (loaded). But loading/unloading was not a problem at all.
Hauling with tailgate down
I recall hauling Maybe a snowmobile or something with the tailgate down and I'm not sure what happened The cables stretched or something but the black plastic on the step bumper made contact with the tailgate
Needless to say I was not a happy camper
It did a nice number on it so be careful that it doesn't bounce too much
Maybe put a piece of 3/4 plywood in the bed to support it and keep it from putting stress on the tailgate?
Since you drive over the tailgate while riding it, the total weight is over 750 lbs. The weight restriction is more of the strength of the cables than what the tailgate itself can hold. The Ford supplied ramps are designed to clip onto the edge of the tailgate so it is stronger than you think. Hopefully that makes sense
Simply lay in two 2x8's that span the distance from your bed front to the edge of the tail gate and remove the weight from the tailgate and let the planks carry the weight for you.
Likewise, if you roll the cart on the truck via a ramp, shore the ramps up from underneath to relieve the gate of the weight of the cart.
