New glow plugs
New glow plugs
Bought new Beru glow plus installed them and now my regulator won't cycle. It will start if you start it everyday but the glow plug regulator won't cycle like it did before. use to click 42 times before it would start and now nothing.
I believe I probably need injectors also if i don't start it everyday it loses prime i believe and won't start. Also smokes blue smoke and puffs it out the exhaust until it gets warm and starts idling smooth. still will smoke but very lite, very strong diesel smell. What do you experienced guys think?
1. The glow plug relay should not click 42 times. That clicking was the controller short cycling because there were glow plugs burnt out. Since you replaced the plugs it should not do that.
2. The wait to start light should come on for 10 sec or so and go out. This is when you start the truck. The controller will short cycle the plugs after the light goes out to help with smoothing out the idle when cold and reduce smoke.
Sounds like you need to replace the return lines between the injectors and that should solve the air intrusion issues.
Not sure bought it as a 7.3. but no labels on it and don't know how to tell them apart. my fuel filter is on the drivers side instead of on the passengers side like i see in most posts.
Received 3,090 Likes
on
first thing to do is get a 12 volt led and wire it into the glow plug relay output. this way you will see when the glow plugs are getting power. once the led goes out start the truck.
just because you do not see a fuel leak on the return lines or caps does not mean air is not leaking in. air molecules are smaller than fuel molecules. so you can have an air intrusion problem but not a fuel leak.
on top of engine behind the breather. Not sure what year engine bought off an individual who bought it to go in his truck but sold the truck to the guy i bought it from and that guy went with a 460. Was bought out of a wrecked truck but he didn't tell me what year. has sat for at least a year in his shop. Just doesn't seem to have a lot of power on hills don't know even if it's a 7.3 or a 6.9?
Ok replaces all my lines and orings and caps. still hard start and when it does it smokes like a freight train for about 10 mins and then clears some but still puffs smoke like Indian signals. but after a while not bad. Think maybe injectors are dripping? Only one way to tell i guess is to pop test um?? After it gets warm it'll start all day no problems except for the light smoke. look like oil but smells like diesel.
Check to make sure you didn't disconnect the engine temp switch - it's located just behind the upper radiator hose connection, next to the alternator. it's a two-prong plug that connects into a switch in the head.
What sound should I hear or be listening for? If I keep it plugged in it will start really quick. Just installed new glow plugs but it acts like it looses it's prime. Replacing the oil regulator right now keep blowing oil filter o rings and the valve was stuck closed. So I won't be trying to start it now until next week when I get that sorted out.
