388 stroker
Old Apr 22, 2016 | 02:09 PM
customfordfan's Avatar
customfordfan
388 stroker
Hey what do you guy's think about this engine? Seems way to cheap but I'm a newbie so maybe I don't know what I'm talking about.... That's why I'm asking! Lol Ford 388W stroker freshly built
Old Apr 22, 2016 | 03:26 PM
buckin69bronco's Avatar
buckin69bronco
Doen't seem too low to be real. If the guy has the build paperwork he may just be taking a loss on the motor.
Old Apr 22, 2016 | 03:40 PM
PA74F250's Avatar
PA74F250
It's cheap enough but I don't like Eagle stuff. They seem to have a reputation for breaking cranks.
Old Apr 22, 2016 | 03:41 PM
Conanski's Avatar
Conanski
I'd guess the guy is just looking to recoup costs of stroker assembly, the block and heads are common and not worth too much. It is a good deal although you would be wise to closely inspect it before buying and even more in depth before using it.
Old Apr 22, 2016 | 04:10 PM
customfordfan
What should I check out if I go look at it? Any ballpark ideas on how much power something like that would make?
Old Apr 22, 2016 | 04:16 PM
flowney's Avatar
flowney
He says it has some run time on an engine stand. Perhaps that's where he decided to sell it rather than use it. I'd want to hear it run first and I'd use a mechanic's stethoscope.
Look on Summit for the cost of this rotating assembly and you might be as skeptical as I am.
Old Apr 22, 2016 | 04:23 PM
Conanski's Avatar
Conanski
I'd want to see documents to verify it's a stroker since there is nothing to see on the outside to indicate a stroker assembly inside. If the motor is a fresh rebuild it should look it, if you find a ratty leaking mess then you have to question the whole story.
With stock heads this motor won't make very remarkable horsepower.. 260-275hp at about 4000rpm, but it should make gobs of torque from idle up.
Old Apr 22, 2016 | 04:38 PM
customfordfan
He says his uncle built it for someone and they couldn't pay it off so he kept the motor.. So would I be able to drop some different heads on it and grab some more power? Like you said I'm a little skeptical unless he can show me some proof of what's inside.
Old Apr 22, 2016 | 06:36 PM
tabascom16's Avatar
tabascom16
It seems like a weird building. Never heard of a 388W stroker. Maybe a 383 kit bored 60 over? Boring a SBF 60 is sometimes suggested as a bad idea as the cylinder walls can become extremely thin.
Why would they use a crappy stroker crank and less than ideal heads, BUT use H-beam rods, possibly a cast iron intake, and balance the assembly?
Seems like a weird combination of someone that really is not an engine building expert, but then again that is just my opinion.
Old Apr 22, 2016 | 07:01 PM
customfordfan
I agree with that!
Old Apr 23, 2016 | 09:09 AM
Motorhead351's Avatar
Motorhead351
If you plan to put better heads and cam in it, then I'd definitely pass.
$2k would go nicely towards a better short block, internals and cam. The heads are worthless as hell.
But if you just wanted something better than stock and ready to go, and it checks out, $2k sounds good for a torquey sbf.
crashmaster79
May 10, 2015 10:20 AM
52 Merc
Feb 6, 2010 06:02 PM
82-100
32
Apr 11, 2009 09:40 AM
guitarnik
18
Dec 10, 2008 06:05 PM
Cope
Jan 22, 2007 12:24 PM
