Putting a 1995 body on a 1987 frame and drive train
Received 3,107 Likes
on
on
on
ok. 87 will be computerized with fuel injection. so even if there is no RABS sensor in the rear axle, you will be able to take the signal for the VSS off the cruise sensor in the tailshaft of the transfer case. at the most, you will have to do a little bit of creative wiring, and you may have to swap out the computer for a 302 unit instead of the 300 unit. engine sensors should not be that bad either, at the worst you my have to get an underhood harness for the 302 for the 95 wiring.
on
Medic42
04-22-2014 06:27 PM
