gas tank options
on
yes.there were some 23 gallon poly tanks.go to car-part.com and see if you can find one.
you'll need to make up your own straps though.-no one makes them anymore.
if you do an advanced search,use my username with tank strap you should find an old thread with info on what i did.
ok.doesn't look like they were offered on f150's.search for f250 f350s then you can select the 23 gal poly option.
this tank im talking about is the midship tank.the one up front.it's not behind the rear axle.so this might not help you.
Dallas2142
08-07-2018 06:27 AM
octaneforce
11-13-2011 10:34 AM
