Door Hinge Pins
Old Apr 19, 2016 | 06:17 PM
matt2491's Avatar
matt2491
Door Hinge Pins
Are the pins in the door hinges supposed to rotate in the arm (that the door bolts to) or in the bracket (that bolts to the cab)?
I had an original set rebuilt by a local shop and noticed that some of the hinge pins rotate in the bracket and others in the arm. I'm not sure whether the shop rebuilt them wrong or if the pin is supposed to just rotate however it wants.
It seems that the pins should rotate in the arm since there is so much more meat there compared to the stamped bracket and won't wear out as quickly.
So does any know how they came from the factory?
Old Apr 19, 2016 | 06:44 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The hinge pins were "cut to fit" and are the same 1961/66 F100/1100 & 1967/72 F100/750.
Old Apr 19, 2016 | 07:19 PM
resonateur's Avatar
resonateur
Matt:
From what I can tell after working on my door hinges, looking at rebuild kits (that wouldn't fit) and finally having them professionally done, I don't think that it matters where the movement occurs. The pins will slide in whichever component has the least amount of bind. As long as there's no vertical play (which you can't tell until you bolt them in and test the long arm), you should be fine. These don't have bronze bushings like some of the hinges, in which the pin is swaged and slides within the bushing. The pin has an interference fit all the way "through" the entire assembly.
Jblack
Mar 2, 2018 08:02 PM
Gicknordon
Dec 19, 2015 08:03 AM
jvmcc
Aug 31, 2014 11:44 AM
Uni Moe
13
Mar 27, 2014 07:10 PM
cberger627
Sep 16, 2009 02:58 AM
