Is this an Engine Knock?
My truck sounds the same. I did UVCH's and no change. I ordered new injectors and will be installing them this weekend. I'll let you know what I find. I was never told it could be low fuel pressure... Hopefully I didn't get new injectors for nothing! I also did my glow plugs for ****s and giggles since I was in there.
Check the heat on each cylinder exhaust manifold and see what one is cold. that should tell you what injector is bad. I had this on number 8 replaced it and all was good. You mitt even find bad o-rings on that cylinder when you pull it. Anyway it's a starting point. It just has to be colder then the rest.
Did you check it when it was cold? As it warms up one will stay much colder then the rest usually, then warm up as you drive it. I had a different problem, It was fine when cold but after I drove it and it idled you could here it badly. Specially between walls. Driving it, it sounded normal.
The obs typically doesn't have the #8 issue since the fuel system isn't dead headed.
#28
#29
#30
Ok, now that I replaced my rear main seal and DMF I can move on to this knock problem. First thing first is a fuel pressure test. Fuel filter is new. I haven't tried cleaning the screen though. Does this pressure seem normal to ya'll? It sure bounces a lot!
7.3L Fuel Pressure Test - YouTube
It looks fine to me.
