Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.7L Power Stroke Diesel
Reload this Page >
"rubbing" noise from brakes after new wheel/tire install
Old 04-18-2016, 10:01 PM
ep120794
ep120794 is offline
ep120794 is starting off with a positive reputation.
I had a friend install 18" rims with 35x12.5 tires on my new 2016 F-250 CC SWB that had 18" stock rims. They came off my 2002 Ford 7.3. There is a "creaking" noise coming out of the brake calipers when moving forward slowly with the brakes applied. This never happened with the tires/rims on my 7.3. Any thoughts on what this could be?
Old 04-19-2016, 05:08 AM
senix's Avatar
senix
senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
are you still appling some brake pressure when it starts to move forward? Slowly releasing the brakes enough for the truck to start to move does it for me.
Old 04-19-2016, 05:26 AM
golfmedik's Avatar
golfmedik
golfmedik is offline
golfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputation
Check the offset and make sure the inside rim isn't hitting the ball joints..
Old 04-19-2016, 05:45 AM
Jmatthews's Avatar
Jmatthews
Jmatthews is offline
is a BAAAD MAN
Jmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputation
2002's had different offsets I know, or else it's unrelated and your shims in the brakes aren't installed right.
I had a bolt come loose from the caliper once on one side and it would swing around and rub the wheel when I hit the brakes. If the wheel isn't rubbing, check the brakes, or put back on your other wheels to see if it quits.
Old 04-19-2016, 07:59 AM
ep120794
ep120794 is offline
The sound is made when I slowly release the brakes while "inching" forward. If I inch forward then stop, inch forward while applying brake then stop, etc is when I hear it. It's like a "groaning" sound.
Old 04-20-2016, 11:45 AM
89LX306
89LX306 is offline
89LX306 has a great reputation on FTE.89LX306 has a great reputation on FTE.89LX306 has a great reputation on FTE.89LX306 has a great reputation on FTE.89LX306 has a great reputation on FTE.
My 2012 does the same thing. I also test drove brand new trucks on the lot that did the same thing when I bought mine. I have owned my '12 since new.
Jsryan7
S. California Chapter
09-01-2017 10:50 PM
CG-ITS
1999 to 2016 Super Duty
15
02-28-2017 07:40 AM
johntpr
02-24-2017 05:15 AM
snapshot
2015+ F150
12-02-2016 07:36 AM
Bigblockboy
06-21-2016 04:59 PM
Quick Reply: "rubbing" noise from brakes after new wheel/tire install
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
