Neither fuel pump works
Old 07-25-2016, 03:03 PM
DIYiT's Avatar
DIYiT
DIYiT is offline
Well, I feel silly.
I am sure I checked all of the fuses over once the night that the truck first shut down. Since then, I've been focusing on the relays and fuses for the fuel pumps and ECU.
Turns out, I missed a fuse in my initial inspection, and then never thought to look at it again since the description didn't prompt me to look into it further.
Fuse #22 was my culprit. So it was that the ECU was dead. It was just a problem with the power to the ECU relay coil circuit. I found a wire that was bare at the coil that must have been chewed on by a rodent that was touching the metal bracket around the coil.
I didn't grab a picture and ran out of time to look into the connector further, but I'll have to wrap it in electrical tape for now. It's not the two wire connector that plugs into the coil directly, but the single-wire (grey??) connector separate from the coil but in the same loom.
I'd like to figure out how to pull the pin out of the connector and replace the wire since about a 4" section is missing insulation and it's right up against the connector so wrapping in tape won't cover it the best (or look nice).
Chris Skoglun
33
04-18-2017 10:32 AM
drivewayford
1997 - 2003 F150
04-06-2014 11:46 PM
tempest411
08-27-2013 12:36 AM
DBANDGB
02-27-2010 03:18 PM
cthaynes
04-22-2002 12:59 PM
Quick Reply: Neither fuel pump works
