56 F1oo Hood Pie Cut
Lots of good info here:
The Art of Pancaking a Hood - Rod & Custom Magazine
Also a real short video that shows a bit how much might look good on a F100:
I tried that Spokane style cut. Did like the "S" cut as I did not have to disturb my rear brace. However pictures do not show how much was cut - I did 1 1/2" at front. Made sure areas I was cutting was the flattest portion. Cut the lower cut first then dropped hood down 1 1/2" in front & screwed front in place to hold the line. Then I used the lower cut edge as a guide to cut the upper part. DO NOT cut the front as when reliefs are cut you need more metal to joint the top/bottom. The front brace had to be cut and the front rod support in the front corners got in the way. Started at mid front and worked out to corners. Just thought I had too many relief cuts at corners
Lawrence Petty
09-23-2016 11:09 AM
52' fordnut
15
02-09-2013 09:50 AM
CharlieLed
08-22-2006 09:28 AM
