Where would the VIN be on the engine?
Hey all
Just bought a 1989 F-350 Crew Cab long bed. The odometer only has 5 digits, but it is *supposed* to be 57,000 original miles on it.
I have an aluminum plate with the VIN on it that I found in the owner's manual like a bookmark. I'm trying to figure out if that plate was what identified the engine VIN. It's pristine - doesn't look a day old. Similar to but not the same shape & info as the one on the dash, although the VIN of course is the same.
I don't know where to look for the VIN otherwise, and Google is of no help other than to say it's at the front of the engine block. I don't see it.
VIN is 2FTJW35G4KCB08921
That plate matches what's on the driver's door and the title.
My goal is to confirm I have the original engine first.
Sounds like the plate you found was the warranty plate (card) that you got back then with a new truck.
There is a drawing number stamped on the bottom of the block near the starter that is cast into the block. This will only get you to a year or so of the casting.
Also sometimes you can get some information off the sticker that is on the rocker cover if it is still there.
I found a couple stamps on the engine. This one is from the left side of the engine.
Truck engine markings
So far, I see little to lead me to believe it has been altered. The only sign I see is the presence of R134 vs the original refrigerant type + a replacement alternator.
Remanufactured alternator
R134 retrofit
R134 retrofit
And here's a photo of the other side of the engine. Hard to get the phone in there for a decent shot.
More engine markings
