1978 - 1996 Big Bronco
Not turning off??
Old 09-21-2016, 06:58 PM
Snakeyes's Avatar
Snakeyes
Snakeyes is offline
Not turning off??
My 95 ford bronco turns on and runs great, However when I turn the key to the off position my bronco won't turn off. The key just loosly turns. I had replaced the lock cylinder and is still doing the same thing. What else might be the problem?
Old 09-21-2016, 09:33 PM
kenh4570's Avatar
kenh4570
kenh4570 is offline
The ignition switch.Or the actuating rod
Old 09-22-2016, 07:54 AM
ManfredVonRichtofen's Avatar
ManfredVonRichtofen
ManfredVonRichtofen is offline
might be the solenoid too. check them connections.
Old 09-22-2016, 12:17 PM
Snakeyes's Avatar
Snakeyes
Snakeyes is offline
Where is that located?
Old 09-27-2016, 09:40 PM
Encho's Avatar
Encho
Encho is offline
The Southernmost Mod
If you're referring to either the solenoid in the fender or the one in the starter, neither will cause this. Those could cause the starter to remain engaged, and you would notice right away.
Old 09-27-2016, 09:59 PM
ManfredVonRichtofen
im talking about the ignition wire that runs to it
Doucheatron
1999 to 2016 Super Duty
03-27-2014 09:10 AM
Bronco Owner
03-03-2014 08:51 PM
the Goat
01-05-2006 08:21 AM
1988-Ranger
1983 - 2012 Ranger & B-Series
06-07-2004 08:00 PM
cfrunz
04-20-2004 12:15 PM
Quick Reply: Not turning off??
