88 F250 Steering Lock Actuator Replacement How-To
Old 04-12-2016, 10:59 AM
cadudite's Avatar
cadudite
cadudite is offline
3rd Gear
A while back I replaced my steering lock actuator. It ended up being the ignition switch on the column that was separating instead of the actuator being worn out. Irregardless, I documented the tear down and may be able to save some of you time diagnosing whether it is the actuator or the switch,
Eric
Old 04-12-2016, 11:58 PM
Ethan Robinson's Avatar
Ethan Robinson
Ethan Robinson is offline
Ha I did this yesterday, I chopped the end off the actuator so the stupid button doesn't have to pushed to remove key wich is what I believe to be reason it breaks
farmtruck101
04-13-2015 01:53 PM
triskadek
05-24-2014 12:52 PM
timmygyu
1978 - 1996 Big Bronco
03-17-2013 10:11 PM
baffledinpa
04-10-2008 07:09 PM
kill_them_all
12-12-2004 04:21 PM
Quick Reply: 88 F250 Steering Lock Actuator Replacement How-To
