Well, I really messed up this time :( Subford Help !
Old 04-11-2016, 09:53 PM
1918ALF
1918ALF is offline
1918ALF is starting off with a positive reputation.
Doesn't pay to get in a hurry. Had my truck down for a month while I installed a firewall re-enforcement plate and a new radio and speakers. Was getting dark and I wanted to get the new battery in. I installed it turned around the wrong way. Then.... I placed the negative cable on the positive side of the battery. Big spark... I knew what I had done, figured no big deal, and turned it around. Started the truck up and now the battery light is on, and the volt meter is on 8 volts. Checked it with my volt meter, and it is indeed not charging. To cap off the night, my new Pioneer radio is dead as a hammer... Checked the fuse for the radio at the fuse box and it is fine. Anyway, another fine mess I have got myself into.... Is there some fusible link I should check, or did I just fry the alternator and the radio with my incompetence? any advise short of shooting myself welcome (I have already thought about that
Scott in Dallas
Old 04-11-2016, 10:49 PM
zemus420's Avatar
zemus420
zemus420 is offline
zemus420 is starting off with a positive reputation.
Scott in Dallas
The radio should have a fuse in the back of it I would check that. The alternator can be removed and taken to be tested at Autozone, Orileys, Napa, Pepboys, and Advanced Auto. Your choice.
Old 04-11-2016, 11:20 PM
Bruners4's Avatar
Bruners4
Bruners4 is online now
Bruners4 is gaining momentum as a positive member of FTE.
I think that there are a couple of fuse links by the battery/solenoid. Didn't catch the year?
Old 04-12-2016, 06:01 AM
tjc transport's Avatar
tjc transport
tjc transport is offline
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
as was already said, radio is probably a blow fuse. and charging system is most likely blown fuseable links. there are 2-3 of them coming off the hot side of the fender mount starter relay. look closely at them, you will see the melted part.
Old 04-12-2016, 08:03 AM
subford's Avatar
subford
subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Check as stated in the above posts and state your year.
TBF250gasser
2004 - 2008 F150
01-05-2018 06:02 PM
Mr. Ed
13
08-19-2017 05:09 PM
Fbg
12-18-2016 03:14 PM
Turbolark
2004 - 2008 F150
15
08-02-2016 10:06 PM
deputydog03
1997-2006 Expedition & Navigator
81
03-08-2016 09:20 PM
Quick Reply: Well, I really messed up this time :( Subford Help !
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
