Throttle body injection and a C6
Anybody tried it yet? Looks like I'll be selling my bronco this summer and realizing the dream of fuel infection for my '77 Bruce. I plan on going with the FiTech setup. The plan is eventually for a 5-speed Tremec TKO trans swap but for now I need to make the C6 work. I'm thinking the Lokar cable setup should work for the kickdown linkage...anybody tried it with a throttle body?
In case you run into problems hooking up the kickdown, just know that you don't need the kickdown. Unlike some transmissions, the C6 only uses the kickdown linkage to drop the trans into passing gear. It doesn't use the linkage to adjust the line pressure, that's what the vacuum modulator does.
Personally, I would preffer to have it hooked up, but it's not critical to the trans operation.
mofoco1
05-11-2017 12:34 PM
CountryBumkin
10-25-2012 04:30 AM
whdahel
03-06-2008 10:49 AM
