2001 SD & '93 f150 opinions...
Old 04-11-2016, 08:53 AM
Thedonk
Thedonk is offline
Thedonk is starting off with a positive reputation.
i have a DD '93 f150 single cab short bed. it is good but i wanna do a solid axle swap in the future. for the same price i have the chance to buy a 2001 SD 7.3l 4x4. i wanna put the two together. if i put everything from the sd on my obs i have to box the frame and swap everything. or i could put the cab of my obs on the sd. because the bed is bad and interior is rough. any thoughts??? also the 7.3 need some fuel system work, but other than that is good
Old 04-12-2016, 05:13 PM
rla2005's Avatar
rla2005
rla2005 is offline
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Trying to mate these two different generation trucks is going to be a nightmare. If you have the time, money and resources...go for it.
Either scenario has it's caveats. Personally I would pass on the Super Duty and stick to plan A (SAS with something known to be compatible).
Old 04-12-2016, 05:50 PM
Nothing Special's Avatar
Nothing Special
Nothing Special is offline
Nothing Special is a name known to allNothing Special is a name known to allNothing Special is a name known to allNothing Special is a name known to allNothing Special is a name known to allNothing Special is a name known to all
I commented in your other thread, but I'm with rla, recommending neither approach. But it's your truck and your life, so I certainly won't be bothered if you go your own direction!
Old 04-12-2016, 09:01 PM
Conanski's Avatar
Conanski
Conanski is offline
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
That diesel really needs the HD frame and suspension to hold it up so IMO it makes no sense to try and transplant all that into an old F150, if you got to swap something put the '03 sheet metal on the SD rolling chassis as best you can.
Old 04-13-2016, 08:28 AM
Thedonk
Thedonk is offline
yeah i think i have decided that i am going to either leave it alone, or sell it and put the money into the truck i have.
Powersmoke_sd
09-07-2017 11:45 AM
Dutter 2
07-21-2017 09:14 AM
01powerstroke73
1999 to 2016 Super Duty
07-21-2017 06:48 AM
IDIoit
09-18-2016 11:12 AM
BradSmith-7.3L
04-15-2016 02:10 PM
Quick Reply: 2001 SD & '93 f150 opinions...
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
