Should I stick with diesel oil or go back to regular?
I almost bought the Motorcraft diesel oil in auto zone jus now but I hesitated when I saw this
Right at the bottom it says do not use in gasoline engines with a catalyst. Doeso my 95 250 have a cat? My apologies for the stupid questions I just don't wanna mess up my motor.
Thanks
Thanks
The PO may be using 15W40 to mask a low oil pressure issue.
Yea the zinc/zddp content is hard on the cat, which is the reason for the warning. bit on the flip side, not having the zinc in the oil is hard on the cam.. Replacing the cat is cheaper than wiping the cam lobes off.
I'd keep using the diesel spec oil, personally, and I do. Much less worried about the cat than I am the cam.
edit: assuming you don't have the 5.8L engine with roller lifters already. If you have a roller engine then the zinc isn't needed..
