1998 Mountaineer Power Antenna to Standard Whip
To remove the antenna assembly you need to remove the antenna base cap (top of fender), remove the nut below the base cap, then remove the fender liner, the bolt at the bottom of the bracket, lower the glove box door, unplug the electrical connector and the antenna cable, push them in to the engine compartment, and remove the antenna assembly from the wheel well area.
-Rod
-Rod
Adam Gross
08-05-2017 08:46 PM
mfp4073
1983 - 2012 Ranger & B-Series
01-15-2008 11:38 AM
Options
07-20-2004 12:58 PM
redn8
07-21-2001 02:07 AM
