electric fans
Old 04-04-2016, 08:10 AM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,151 Likes on 910 Posts
Originally Posted by grumpyinme.
I am going to dump the 410 gears and go with 373.
Why?
The change is so small it will be unnoticeable. A taller set of tires would be cheaper in the long run.
Old 04-04-2016, 08:22 AM
grumpyinme.'s Avatar
grumpyinme.
grumpyinme. is offline
how tall would have to go to make the difference?
Old 04-04-2016, 09:40 AM
'89F2urd's Avatar
'89F2urd
'89F2urd is offline
Some 33's, 285's, or 305's are nice combo with 410s. I love my 37s and 410s, it's essentially the same as 3.55s....I have enough power to bury the speedo with ease though, stock engine wouldn't like more than 33s.
Old 04-04-2016, 09:48 AM
grumpyinme.
interesting,I will check into this.whats on it now are 265/75-16,brand new when I got it.less than 2000 on them.have to be the next set.thanks for that info
Old 04-04-2016, 08:02 PM
rla2005's Avatar
rla2005
rla2005 is offline
Taller tires lower the effective axle ratio. 10% taller tires are like changing to a 3.73 ratio.
Old 04-04-2016, 09:01 PM
wtroger's Avatar
wtroger
wtroger is offline
I am using a Mark VIII Lincoln fan on a 1995 f250. I have the two speed set up so high comes on on a thermostat low comes on with ac compressor. Works pretty well.
Old 04-04-2016, 11:40 PM
Lead Head's Avatar
Lead Head
Lead Head is offline
Originally Posted by '89F2urd
I disagree, big truck fans soak up substantial amounts of power...relatively speaking. When my fan is whirling on my 351, I barely feel it. When it's whirling in my dodge it sounds like a wind tunnel and I feel it engaging and releasing.
I've built many electric fan setups with nothing more than old taurus fans...if you build a tightly sealed shroud and use 2 of those (or better) you will be fine.
With a properly working fan clutch it's not an issue, especially on a 460 which already gets trashcan fuel economy.
Old 04-05-2016, 04:08 AM
'89F2urd's Avatar
'89F2urd
'89F2urd is offline
Not an issue? Sure, cant disagree with that, especially for 90% of the people out there that won't notice anything different either way. Does it draw noticeable power? Definitely, and the hotter it gets the easier it is to notice.
As for mileage, whether or not it's actually effected depends entirely on engagement. If It's 5* outside, and your taking a trip to the grocery store, it'll never engage substantially anyway. If it's 100* and you're towing heavy, it's definitely engaging hard and using gas to turn....the fact that the truck is getting 6-8 mpg is the only reason it's irrelevant.
It's all relative, and obviously e fans aren't the norm because most people wouldn't notice a benefit one way or another...but there are circumstances where they fit, especially if max power is what you're after.
Old 04-05-2016, 12:55 PM
grumpyinme.
I think I still might play with the fans,I have the 2 10 ons and look into the mark one.right now she is coming apart to replace the oil cooler with a remote one,and remote fiters.
FordF350Baby
02-02-2021 01:12 AM
Powerhouse ABO
01-11-2013 09:22 AM
MAKO314
15
08-27-2008 08:37 AM
bucks77ford
08-12-2008 01:10 PM
hotrod 250
02-10-2008 09:36 PM
Quick Reply: electric fans
