Cant get toyota pitman arm off!!
Man, I am having a heck of a time here. I'm so excited to get my new column, box, steering wheel on. But I can't get this dang arm off! The box is not on a vehicle, and I just can't seem to get the thing to budge.
I have read and tried to tighten it as much as I can and hit it with a hammer. I tried doing that and then readjusting the puller to hit it on another side. Nada!
I haven't tried any heat. I don't have an air compressor here at my house. Do you think that using an impact on the puller would be a game changer?
Worth a shot thank you! Maybe time to invest in a simple torch...and maybe a battery powered impact for my garage (it's hard for me to pay the $$ for a compressor setup because my brother has a nice setup at his house 15 mins down the road. I'd rather spend the $500 or so on truck parts! )
What makes the impact so effective is the shock that it applies in the internal hammering action of the impact. This is the same effect you will get by rapping the end of the puller bolt while torqueing the bolt. As for the heat, oldmerc is correct but with a little care heat can be applied to the arm without overheating the shaft...if the arm can be heated the metal will expand enough to free itself.
10-4 and 10-4! I'll keep you posted...
If you try the torch idea I suggest you wrap the steering box and shaft with some old towels and soak them with water. This will protect them and keep them cool. Keep an eye out to make sure they don't catch on fire. Keep extra water around.
Not sure if the puller will stand up to the impact gun. Plus, if you built up enough torque and it failed you might end up with a deadly missile. I would hand torque it and go to work with the torch. Spread the heat around the pittman arm. Keep heating ans whacking. She should let go.
Might try to think of a shop right now...trying to think of what "type" of shop to put in the old Google!
I have considered this...but was trying to save the pitman arm so I could sell it to mid fifty in May at the F100 supernats ($10). The frustration is probably not worth $10 though....haha
I had to use an impact while tapping it and then off it came. If you can help it do not ruin the arm and or box. Are you installing power steering ?
If you get a chance check out my post of leaning to the left as I put the same springs in that you did but not a drop axle and I was wondering how much clearance you have ?
I'll check out your post. So far so good with the motor in and the front sheet metal on, I still have some room for travel with the lowering springs and drop axle. I figure I may have to heat and bend the steering arm eventually to get it level.
I work for a software company that provides software solutions to car dealerships. I'm going to bring my box with pitman arm attached to a Ford dealer that I'm visiting tomorrow and see if they can help me out. The owner of the dealership is building an F1 and will hopefully be willing to give me a hand!
