Wheelchair conversion discussion
#61
#62
If you use a manual chair, the Bruan Vangater is an option, it is what I have that is 21 years old, mine being the original from the company that designed it, screw drive, the platform folds clearing the doorway when not in use. Mine would make a salesman have a stroke now tho, the roll stop on the end is missing pieces, no longer working, wore out, but thats it.
#63
The Ricon S2000 in mine has yet to leak anything, it's a 1995 unit too, yet it doesn't slide, a friend has the clearway, it's as old as mine and heavily used, it doesn't fold anymore, the devices wore out and were removed, but could be replaced. Hydraulic is the way to go but less movement is even better, but that said, my Crow River is also from 1995 with some years of heavy use, it still works but the micro switches are buggy, along with the big motor sounds like the armature is burnt up.
Since starting this thread I ended up divorced, and we split costs on the van because we consider it as belonging to our daughter. Karri wants to trade for a converted minivan, which is something we are looking into closely. I'm inclined to see how we like the new lift before jumping ship like that, especially after how well our dealer has treated us with all of this. We'll see.
#64
That's good to hear. Our daughter is only 6, and she's only needed a lift since she got her power wheelchair just under two years ago. So we're relatively new to this, and the current lift really gives us a sour opinion of Ricon in general.
#66
Mini vans are extremely close to the ground and after conversion they will drag on the slightest incline, just turning into a parking lot from the road will often require you coming to a stop as they will bottom out, this I know too well. The friend with the clear view Ricon, that van has 400,000+ miles on it as he drove it to his wheelchair rugby matches along with his commute to work being long, it is basically the same as my commercial version but with the split platform added. The mini van is killed by having the floor dropped 12+ inches to accommodate the wheelchair, they lift the suspension a little but makes no difference because if you look closely they are a mere inches from the ground, I can't see how you've not bottomed one out.
Part of that is the way they do their conversions. Rollx is one of the handful of manufacturers of converted minivans in the country, and they don't seem to do anything to beef up the suspension. They all ride terribly when we put Hannah in, and therefore we aren't interested in owning one of them. After the last time it was repaired, I went straight to a Braun dealer and set up a test drive of one of theirs. The difference was like night and day, they use a load leveling rear suspension that seems to be able to handle the weight of a power wheelchair. This is the direction we would go if we decide to downsize.
#67
#68
https://www.rollxvans.com/?gclid=Cj0...4aAkqIEALw_wcB
They're good people who seem to really care, but not the level of quality that the big nationwide companies like Braun seem to have.
#69
I wish I had seen this thread back in 2016... I have some second hand experience with lift-equipped vans. A good friend from high school had one in the early 90's. His was an E-150, standard-roof with a side lift, also modified for him to drive it. He sold it after he wasn't able to drive any his family replaced it with a dropped floor minivan.
In the Philadelphia area, he discovered that even a std-roof E-150 (shorter height than heavier 250 and 350 vans) still was too tall to fit into most parking garages.
The side lift essentially took up all of the middle of the van. It also limited the rear-ward travel of the front passenger seat. If he was driving it was a 4-person vehicle; him driving, plus front passenger and two passengers way back on the rear bench. If he was locked into the middle position and the OE driver's seat was installed, it could carry 5 total.
His van was a V6 and he wished they had sprung for the V8 as the V6 had to work so hard with the weight there was no MPG savings. Like the OP, he had to buy the van and the conversion was covered by a State disability program.
As I searched for my van, I saw a lot of handicap conversions for sale.
#70
We have no state help with purchase here, dad bought my stuff used and had it installed in a van he found for me, it made it a year before I replaced it with a 99 E350 in 2002, having the equipment transferred to it, wish I had gotten a newer lift tho. The Bruan Vangater doesn't affect the passenger seat like the hydraulic lift due to there being the lift arm is on one side, not both, but it is not as durable or capable of heavy lifting either.
A rear lift is not as hard on the suspension due to the rear having the more durable leaf springs, takes longer before they break down, you will find most converted vans with moderate use all lean to the passenger side.
#71
I've had two 3.5L EcoBoost-powered trucks and they were fantastic, unfortunately the EcoBoost engine is a harder thing to find in the used van market. I would have happily spent a bit more for it, but they were just too hard to find.
#73
I'd think I found a viable lift. But they want $700 for it.
https://stlouis.craigslist.org/pts/d...466566612.html
Are you interested in the SlideAway they're ripping out of my Transit? I have no idea what they plan on doing with it, but I can ask for ya.
I think that thing is trouble, though...4 hydraulic leaks in a year-and-a-half. We're very happy it's being replaced.
#74
#75
Tom -
I'm not entirely sure. His family typically bought Fords, so it might have been whatever minivan Ford was making at the time. Sadly, my friend passed away back in 2009 (his condition was degenerative, so we all subconsciously knew he would pass young) and the van is long gone.
Fortunately, there are more van options and better technology now than back in the early 90's. The base E-series V6 was (IIRC) the 4.2L "Essex" engine. I don't know much about it other than he felt it lacked power and didn't give the better fuel economy he was hoping for. At the time he was commuting to graduate school in Philly.
