Flooding after installing MAF
Old Aug 12, 2003 | 06:00 PM
Big Red Bronco's Avatar
Big Red Bronco
Hi, I have a 1989 Bronco, 351W. I installed the Ford Racing Performance parts MAF kit. It worked fine for a couple of months and then just started causing severe flooding problems.
Calls to Ford tech gave me no answers.
I've reinstalled the intake gaskets, replaced all the sensors, and rechecked them to make sure they are working correctly. There are no vacum leaks no internal coolent leaks. Pressure regulator was changed and fuel pressure is dead on.
Just severe flooding problems.
Any ideas as to what I should look at/do???
Thanks
Bruce (Big Red Bronco)
Old Aug 16, 2003 | 07:58 PM
fireguy50's Avatar
fireguy50
check the codes.
what injectors? what MAF sensor? what computer?
Old Aug 17, 2003 | 12:10 AM
Ford_Six's Avatar
Ford_Six
I'd check the connector on the maf to make sure there isn't any water in it, or corrosion.
Old Aug 17, 2003 | 01:51 AM
LxMan1's Avatar
LxMan1
Could be an injector not shutting off and dumping fuel all of the time.
Jimmy
