In Need Of Electrical Gurus - Brake Light/Turn Signal Issue
Hi All,
First post to the forum....new owner of an 04 F250 6.0L!!
An issue I noticed right off the bat was that whenever I had the driver side turn signal on, and the brake was applied, the turn signal freezes.
I took apart the tail light and found a concoction of wires...I posted a diagram illustrating what it looks like.
There is this pesky Red wire that is spliced into the tail light bulb socket wire (specifically the green wire).
There is a trailer brake installed...if this means anything. I've tried disconnecting that with no luck on fixing the issue.
Any thoughts or suggestions on how to further troubleshoot would be great...electrical work is not my forte!
Thank you in advance!
Thanks for the response blade.
The 'add-on' stuff is just a simple brake controller, and it doesn't seem to have any effect whether it's plugged or unplugged.
When you say the 'brake light wire', are you referring to that pesky spliced-in Red wire or the factory green wire on the bulb socket?
Remember, the factory green wire should control both the turn signal and brake light. For some reason on my truck, they had to splice in a Red wire in order to get the brake light to work...even though it then freezes the turn signal as a result.
Sean,
Thanks for providing those diagrams...full disclosure...I'm not electrically inclined whatsoever. Not quite sure why I need that random Red wire coming into my factory green wire if the green wire is supposed to deliver power.
And remember, the green wire DOES deliver power because the turn signal works when the red wire is removed...but not the brake light.
Thoughts from anyone who is more familiar with reading these diagrams?
The diagrams will give you the color of each wire as it was built from ford.
These 3 PDFs should be very helpful for the people that are not good with electrical
or that don't have any experience at all. They are the key on reading the diagrams.
Sean <BR>
6.0L Tech Folder
Sean <BR>
6.0L Tech Folder
Welcome to FTE Bob. If you have a vom,start by familirizing with what each wire on RIGHT side does and when it does it. If you don't have a vom,buy one and start learning to use it or forget about troubleshooting modern cars. I didn't see green on the scimatics but if you have 2 black and 1 green,green is most likly ground and is common to body of truck. Check right side light to find out (A) if green is common to ground (B) if there is a tracer or other way such as size of telling one black from the other. Returning to left light,disconnect red wire for now then make sure left is wired same as right. If my hunch is right green is not a good ground (if indeed that's what it was on right). There should be no resistance between bulb socket and chassis of truck. If resistance is found,jumper a temporary ground to socket then try turn,brake and park lights. Report back
Update: The brake lights/turn signal outage was caused by the #18 fuse (20A) going out.
Replaced that and I'm back to my original state....brake lights work, turn signals work, but left turn signal freezes when brakes applied.
Will be in and out of town on business the next few weeks but will look into Da-Bees suggestions.
