Depending on offset if you have 10" wide rims with just a leveling kit they may rub regardless of tire size....the width/offset is the issue...not the height.
I went with 22x11 with a -24 offset running 325 50 22's which is a 35" tire with no rub. I used a ready lift stage 4 kit which gives you 3 1/2" of lift. Easiest kit to install and no Rub.
