Ambient temperature readings (just curious)
My console display usually coincides pretty closely with what the weather report tells me the temps are. OBD II PID 46, displayed via an UltraGauge, always displays temps about 3-5 degrees cooler than the console display. Can anyone explain to me the difference in how ambient temperatures are calculated by the console display vs OBD II PID 46 (ambient temperature)?
Intake air temp is PID 0F.
I use the now discontinued MSD dashawk and they are separate sensors. Once on the road, the IAT and OAT are within one degree. Air is pulled in by the left front fender and since its they are about he same, no reason to go with a cold air intake. If I select the OAT on the dashawk, it is the same as the temperature displayed on the dashboard.
Well I was just curious. It was nothing vital.
