aftermarket 53-56 F100 front fenders
My own experience with reproduction parts was even worse than that. I had one piece of a fender spot welded in the wrong position; I had to un-attach it and re-weld so that the front of the fender aligned with the nose of the hood. What was most frustrating for me was how much time I spent trying to get the front sheet metal to align before I realized that the problem was in the construction quality of the reproduction. Knowing in advance that reproduction parts may need work would have tempered my own initial disappointment. I'm happy with how things worked out in the end, but anyone buying reproduction parts should not expect to simply bolt them in place and call it done. I do not know if one vendor is much different than another.
I got a right front fender from Mid West Early Ford. I don't know where they get them from. The only difference I could tell was that the repop felt lighter in weight than my original. But that could be because my original had several coats of paint on it. But I think the repop was a smaller gauge.
My body man has not complained to me about a bad fit.
Received 4,130 Likes
on
The new rear fenders I got feel pretty light too compared to the rusty one I had but maybe I'm stronger now too
on
Every new piece looks fantastic when it comes out of the box , it's when you start putting the pieces together you find out it's a piece of another puzzle that you need to make fit
on
on
#30
