Sound deadening advice...
Hello all: I just started a 1965 F100 352 cu in. 4 Sp.
I am removing foam rubber someone stuffed in beside the fuel tank. It makes me think sound deadening is a good idea.
Is there a good sound deadening material that I can install that won't hold moisture, turn to sponge cake, behind, beside fuel tank? Maybe even above the head liner when I replace that?
Dacron?
And related, I want to try to do my own upholstery will i need to replace springs or just the foam rubber and vinyl?
Wondering in Weatherford.
Dacron?
I've used B-Quiet Ultimate in 2 restorations. Works well on the floor, inside doors, above the headliner.
B-Quiet Extreme 50 sq.ft. Roll
Remember, no matter what you end up using, make very sure the surface you are going to apply the material to, is absolutely clean and free of dirt, grease, and even wax. I cannot stress the importance of this. Especially when putting it on a area where it needs to hang.
There is a professional product you can get from your local automotive paint supply that is made especially for cleaning surfaces and not leaving any residue.
Well worth getting before you do the job.
TnBuckeye
17
01-29-2016 03:20 PM
whatthencuz
13
09-19-2009 11:56 PM
discman
04-24-2005 11:00 AM
