Tail lights always on 1989 F-250
Old 03-19-2016, 03:46 PM
Cummins7mm
Cummins7mm is offline
Cummins7mm is starting off with a positive reputation.
I have a 1989 F-250 7.5 and the tail lights are always on, it never used to do it before, I don't know why it started recently. I have unplugged the brake controller (could be messed up anyway), unplugged the trailer tow relay changed the brake light switch on the pedal. They are not the factory lights however because the truck has a utility box with LEDs. This is mainly a
problem because it will not let my cruise come on. Forgot to mention before this started the cruise would work but if you hit a bump the cruise would kick off.
Last edited by Cummins7mm; 03-19-2016 at 04:00 PM. Reason: Forgot to mention before this started the cruise would work but if you hit s bump the cruise would kick off
Old 03-19-2016, 04:13 PM
bashby's Avatar
bashby
bashby is offline
bashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to all
Do they go off if you unplug the brake light switch?
Old 03-19-2016, 04:49 PM
eakermeld's Avatar
eakermeld
eakermeld is offline
eakermeld is gaining momentum as a positive member of FTE.eakermeld is gaining momentum as a positive member of FTE.
LED's are known to cause strange problems, especially, but not limited to, automatics. There is an in-line resistor that can be added to solve this kind of problem. It mimics the resistance of an incandescent bulb.
Old 03-20-2016, 07:04 PM
Cummins7mm
Correct me if I'm wrong, but doesn't the brake lights coming on kick the cruise off? If so the cruise was working a few weeks ago.
Old 03-20-2016, 07:26 PM
Cummins7mm
I am going to get a new ignition switch because I have no accessory position on my radio, after that I will probably get a new brake light switch
jasondinsmoore
1999 to 2016 Super Duty
22
01-07-2019 06:16 PM
z31freakify
08-17-2017 08:46 AM
finitetime
03-24-2017 10:02 PM
Cummins7mm
04-22-2016 11:07 AM
MAHighboy77
03-27-2016 09:24 PM
Quick Reply: Tail lights always on 1989 F-250
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
