93 f250 rear main seal replacement
Hey guys on my 93 f250 the rear main needs replaced. It has the 5.8 windsor with a 5 speed manual. My question about the whole this is when I remove the pressure plate and cover assembly am I goin to have to bleed the clutch when its all back together. Helped a buddy do a rear main but the engine was outa the pickup.
It's the easiest hydraulic setup to bleed....there's a bleeder screw on the slave cylinder, have a buddy pump the clutch pedal just the way you would when bleeding brakes. Pump pedal, hold pedal to floor, crack screw, tighten screw, repeat.
You can technically pull the trans back far enough to work on the clutch/seal but that's honestly more trouble than its worth.
I wouldn't use any type of flush.
Just use a conventional motor oil and replace 1 quart with MMO and drive for several hundred miles. Repeat. I usually just swap the filter and repeat. Did this to my new to '95, 302. Did it 3 times and it's just now looking clean on the dipstick.
Or switch to a diesel rated oil, Rotella or Delo and do the same. Diesel rated oil has more detergents.
Only other way to get it clean is to pull and strip it....
fordzilla01
04-08-2008 08:33 AM
maddogblack
08-30-2007 01:34 PM
73f100shortbed
06-13-2006 07:54 PM
Little Bro
09-07-2004 06:22 PM
