Oh No! Head Gasket??
Old 03-15-2016, 08:17 AM
52 USCG Panel's Avatar
52 USCG Panel
52 USCG Panel is offline
I have some commitments this morning, so don't have time until this afternoon to drain the fluids. I did check the oil again, however, and it is up about a quarter of an inch on the stick and still looks good. The oil cap/breather also looks good. I took a sample of antifreeze off the top with a turkey baster. It's dirty, but maybe ok. What do you think?
Old 03-15-2016, 09:05 AM
abe's Avatar
abe
abe is offline
One Meadow Green Owner
Received 2,597 Likes on 1,443 Posts
Looks good to me, but the bigger question is how does the wife's turkey baster look?
I used my wife's once and now it is in my garage permantly. I don't know why she wanted a new one for the kitchen?
Old 03-15-2016, 09:48 AM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
That's definitely old juice there, a good flush will be in order.
Old 03-15-2016, 11:33 AM
Mixer man's Avatar
Mixer man
Mixer man is offline
What Ross said.
A thorough chemical flush and back flush rinse.
Old 03-15-2016, 12:12 PM
52 USCG Panel
Abe, you are so right! I "borrowed" the baster years ago, and it has been in the garage ever since. It must be a genetic thing. In certain circumstances, all women seem to react in the same way--I guess maybe men do too. We should do a little poll to find out the average number of turkey basters in FTE households; then compare our data to the general population. I'm guessing FTE member households will have more turkey basters.
Old 03-15-2016, 12:19 PM
52 USCG Panel
Mixer Man & Ross, I'll give your suggestion a try and hope for the best. The antifreeze is less than 6 months old with less than a 100 miles on it, but I carelessly made no attempt to flush the block before installing it.
Old 03-15-2016, 12:21 PM
raytasch's Avatar
raytasch
raytasch is offline
Believe Nothing
Turkey basters morph into fluid handlers. I know this to be fact.
Old 03-15-2016, 01:08 PM
3twinridges's Avatar
3twinridges
3twinridges is offline
While you are changing the coolant and flushing it out, I would also get a new radiator cap, that one looks toasty and the spring is probably not fully functional and corroded.
Old 03-15-2016, 02:10 PM
Mixer man's Avatar
Mixer man
This is what I did, but not everyone is as **** about this as I am.
Coolant recovery.
Coolant filter.
Old 03-15-2016, 02:44 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Is there a chance there was still a lot of old antifreeze (or acid flush solution) hiding in the block and heater core? I've never seen antifreeze go bad that quickly.
Old 03-15-2016, 02:54 PM
52 USCG Panel
The guy that worked on my wiring has a machine for flushing cooling systems. I made an appointment for Thursday. I'll take care of the water pump at the same time. Good idea, Mixer Man for capturing your radiator's overflow. A coolant filter is something I've never considered before.
I guess the jury is still out reguarding wether or not oil is getting into my antifreeze. I'm hoping though that a good flush of my system and a different radiator cap will be all that is needed.
Thanks everyone for your thoughtful analysis of my problem. I'll be sure to let you know if a cooling system flush was the answer.
Old 03-15-2016, 03:04 PM
MattK1's Avatar
MattK1
MattK1 is offline
I don't think you are getting oil in that coolant. It is usually much more milk chocolate looking. I bet a good flush will take care of you.
  #28
Old 03-15-2016, 03:06 PM
52 USCG Panel
Ross, I understand what you are saying. The "stuff" on my radiator cap is pretty nasty, and it is a bit of a stretch to attribute it to just some old residue left in the block. There would not have been any acid or chemicals--just what my Dad put in for antifreeze sometime in the 1960"s. And as I mentioned--the old antifreeze didn't look too bad when it was drained out. I guess we'll see after Thursday.
  #29
Old 03-15-2016, 03:13 PM
MattK1's Avatar
MattK1
MattK1 is offline
Coolant will breakdown & have a reaction to the metals in your engine & cooling system over time. It can def build a sludge. Google it & click the images. It is quite surprising how bad it can get.
  #30
Old 03-16-2016, 12:35 PM
Mixer man's Avatar
Mixer man
One of the benefits of a coolant recovery system is that it prevents air from being introduced into the cooling system. The coolant filter captures casting sand, debris, and sludge. And we all know that casting sand is ever present because these small engine castings aren't sealed. One of the largest causes of coolant pump seal failure, and impeller erosion.
Quick Reply: Oh No! Head Gasket??
