Eaton axel question
#31
#32
I'm not apposed to a 7.3 out of a 2wd f350.
I subscribe to a thought process that states mind over matter if you don't mind it don't matter
#34
Post 27 has one, but just to save you the steps:
http://www.powerforce.com/pdfs/trans...s_pf_mt653.pdf
#36
#38
#39
Some discussion here:
Allison AT 545 Auto???
They reference Suncoast as a source for a custom converter. Nothing on their site about Allisons other than those in GM pickups.
GM Converters
You mentioned maybe a repower with a 7.3? All things considered, depending on how much your truck weighs, you might be happier with a repower, an OD trans with lockup, and probably less fuel and maintenance costs. Serving suggestion.
GM Converters
#42
I will NOT put a standard transmission in my truck. That is way to much work to operate. I've found a 8.9 in a truck with a 653, and that's the way I may go after talking to people who really know what they are talking about. I will be happier with a engine I can hot rod and a 7.3 is a good option. I got an old ambulance with engine and transmission 7.3 with OD for 1200.00. It's got 350k on it but I can rebuild her and jam that in my big truck and have at it. I'm not set on my plan of attack but I will be speaking to people this weekend that I have full confidence in their knowledge in regards to diesel ages and automatic transmissions I will never put a manual transmission in the truck for towing ever is the most uncomfortable thing to make a left-hand turns in attack but I will be speaking to people this weekend that I have full confidence in their knowledge in regards to diesel ages and automatic transmissions I will never put a manual transmission in the truck for towing ever is the most uncomfortable thing to make a left-hand turns in. I have a class A with no restrictions and the last thing I want to do is jam gears.
#43
#45
5.9 and 8.3 are both good engines (I have both of them) but I don't understand the intended part, the 7.8 Ford 6 cyl turbo diesel in his truck only came in medium duty Ford trucks.
