LED Hood Light Mod
Ken how tall are them lights ??
Because after reading your write up and thinking about it I'm going to get a few of them KC lights for my underhood. I am thinking of also putting one under the cowl.
Do you think if you put one underside of cowl over the turbo it would be too hot?
Thanks again for sharing this with us!
There is a certain precision and attention to detail that is the hallmark of just about everything that Ken (Woodnthings) does that is delightful. This craftsmanship is not only self evident in the content of his write ups, but also in the presentation. Ken, your contributions are more deserving than mere reps can reward... they merit real and genuine compliments on your style.
Uber-Geek enters the room....
I had a pair of KC HiLites Cyclone 1350s sitting on the bench, right next to my box of 12VDC power supplies and across from drawer with the Wago quick-taps. My shop at work has no windows, so I figured "Let's see what these bad boys can do".
No outside light, iPhony 4 camera with no flash.
Geek stuff: After this little test, I grabbed a 12VDC 1 amp power supply and hooked it up to the two lights. Once the halo-shaped sunburns on my retinas ebbed, I looked at the specs on the old anemic under-hood bulb
912 bulb:
1 amp
150 lumens
One of these KC HiLites:
0.4 amp
1100 lumens.
Over 7 times more light with less than half the amps - but 25 times the price. Still - I wanna see in there at night (and daytime), and dragging lamps and cords around gets old.
912 bulb:
1 amp
150 lumens
0.4 amp
1100 lumens.
#29
#30
@7.3Excursion4X4: does not having the factory heat blanket thing under the hood effect anything? I'm trying to decide if I should replace mine or just toss it as mine is very tatty and I hate when things look all tatty and bad
