2009 F-150 Back-Up Camera Wiring Help
After backing my F-150 into a concrete filled steel pipe, which was not visible in the mirrors, I decided I needed to install a back-up TV camera. I bought BOYO Model VTC424R kit to install. The installation of the rear camera was a breeze. There is an RF link between the rear camera and the cab monitor. The instruction glibly state, find the under dash electric connector and determine using the shift lever by shifting into reverse, which wire is for the back-up lights and wire the monitor to that wire.
So much easier said than done! I have no idea where even to begin looking to find said connector. Can some one point me to a wiring schematic of the F-150 truck so I can get some idea of what and where to look to find the correct connector. Maybe someone has done the installation and can tell me exactly where to look. Thanks.
Bill
Bill
The camera transmit an RF signal to the monitor in the cab, which displays what the camera sees. The instruction are to wire the monitor to the connector which is live when the shift lever is in the Reverse position. The monitor is then only powered when the shift lever is in the reverse position. Not having any idea which or where the connector which has the Reverse wire would be located, installation of the monitor is currently on hold.
ceerebus
07-12-2017 09:02 AM
crestfallinman
08-23-2009 08:47 PM
Hunt4Fun
11-01-2007 04:55 AM
