1974 F-600 dump help
#46
The back side of the fuel pump can leak directly into the crankcase. If that is happening, it will be evident when you pull the pump. Try to preserve the metal fuel lines between the pump and carb. They sometimes get bent or twisted. They are much safer than the usual auto parts store rubber hose.
A failed needle and seat in the carb can also drain gas down the intake and past the rings.
Grinding into 1st and R is normal. These are non-synchro gears. You can, as suggested, hold the clutch a little longer before pushing into the gear. Or, you can just run the trans into 4th or 3rd or whatever your pattern makes easiest, then go directly into 1st or R. The engagement of one gear stops all the twirly bits from spinning in the trans, making engagement of 1st or R easier despite the lack of a synchro.
#47
#51
Welcome to FTE. Your question was answered in the other thread you posted in:
https://www.ford-trucks.com/forums/1...-decode-9.html
