Using a pressure bleeder on clutch system?
Old Mar 7, 2016 | 09:19 AM
shultzaberger's Avatar
shultzaberger
Just picked up a 2003 Ranger XL 2.3L and notice that I get a little grinding every now and then when shifting into 1st gear. The clutch was replaced 3 years ago according to the PO but had no clue as to how long it's been since the clutch was bled.
I've used my Motive pressure bleeder numerous times in the past on brakes with much success but I've never used it on the clutch. I've used vacuum bleeders as well but it's always a 50/50 success rate with that. The pressure bleeder just works much better for me.
Has anyone ever used a pressure bleeder on a clutch and if so do you have any tips like still needing to tip the master cylinder end up to release any potentially trapped air bubbles?
Thanks!
Old Mar 10, 2016 | 10:54 PM
Mikeman's Avatar
Mikeman
If you just picked it up, I'm guessing that the tranny fluid has never been replaced. Most people don't (true of other fluids as well). I would change the tranny fluid, if you haven't already done so.
The first thing I do when I buy a used car is catch it up on the maintenance that it hasn't gotten.
I've never used a pressure bleeder, although I've thought about it. I don't think my kit has an adapter for the clutch reservoir. If you try it, post back with results.
Old Mar 11, 2016 | 12:20 PM
shultzaberger
Thanks Mikeman.
Catching up on the maintenance is exactly what I'm doing. Just finished replacing the sway bar links (neither links had bushings on them any more) and the sway bar bushings (completely shot) last night. Next up is shocks as all of them have shrunken, dried up rubber bushings and make quite the racket.
Yeah, I think I'll do the transmission oil next along with checking out the brakes. I believe the 5-spd manual takes Mercon ATF? That's not Mercon V right, just plain Mercon ATF?
Old Mar 11, 2016 | 07:23 PM
Mikeman's Avatar
Mikeman
If you're catching up on maintenance, you should go here and get an owner manual: https://owner.ford.com/tools/account...h-results.html
It will have the specs for all the fluids you're changing.
Old Mar 12, 2016 | 03:18 PM
shultzaberger
Sweet! Thanks!
Old Mar 13, 2016 | 01:25 PM
reddog99's Avatar
reddog99
Originally Posted by shultzaberger
...Yeah, I think I'll do the transmission oil next along with checking out the brakes. I believe the 5-spd manual takes Mercon ATF? That's not Mercon V right, just plain Mercon ATF?
Mercon V is a replacement for everything Mercon.
jetdoc
21
Jul 15, 2007 08:38 PM
mds79
May 26, 2005 10:20 AM
OhNo
Nov 5, 2003 07:12 PM
cbwarrior
Aug 23, 2001 11:14 PM
