Dieselsite max ac
would be helpful if they provided some actual results of the temp drop of the air coming out of the vents.
they say 10* temp reduction of the "duct" but if you look at the path of the air flow around the heater core and the AC there is not much contact with the heater core "duct" when the blend door is diverting air to the AC.
not saying this valve doesn't work, just curious how much it drops the air temp coming out of the vent.
my guess would be less then the 10*
not my pic so ignore the "cut " notations. but you can see the air path if you study the pic.
I don't know how much it actually reduces the temp, but it does make a very marked difference. I compared my previous '02 F250 against my buddy's '99 F250 and there was a big difference.
Even 8 degrees is big tho, especially when it's friggen triple digits outside.
I'll hit my buddy up for you and see if he took any before and after temp readings.
Stewart
Yes, Excursions already have this.
Stewart
Stewart
would be interesting to know.
I am a HVAC newb but if understand correctly the way to measure AC performance is the temperature deferential from inlet air temp to air discharge temp ?
that is why the AC max feature on cars recirculates the cabin air instead of pulling in the outside hot air. cool air in, cooler air out.
IIRC, all the vacuum actuated valve does is detour hot coolant from the heater core, allowing a cooler AC discharge.
I just got back from a walk, so I'll send a PM to Andy and ask him to post here so you can get first-hand info.
Stewart
Edit: Der, I'll just tag him. @Fat Diesel
I don't think that's accurate.
Our 2002 Excursion did not have one from factory.
In the 7.3Ls, it's VERY rare to have a valve already installed from factory but it does happen. Usually it's the later years (2001-2003) and the fully loaded option trucks. I don't think it being an Excursion or not made a difference.
Once they went to the 6.0L, it was much more common to see the valve. 6.0L guy should almost always check before buying a valve. 7.3L guy might not need to check but should buy a lotto ticket if he has one when he goes to install.
kr98664
06-25-2017 10:32 PM
Joyner1100
6.4L Power Stroke Diesel
15
07-25-2012 05:06 AM
daliwong
1999 to 2016 Super Duty
20
06-16-2007 08:32 PM
