Fordguy2100's Hoosier build thread
#91
#93
The wire plug, one is for your choke and the other I forgot. As for the spider webbing on the cover, that's normal from the casting of the cover from the manufacturer.
If it's one thing I really hate to do, it's working in the cold. Sometimes it's just better to wait till it's warmer out.
#94
on
Or am I reading into your post too much?
#97
Originally Posted by grinnergetter
Let me know when your ready to weld. I'll give you a day or two.
Keep at it....I learned more than i ever wanted to know about Ford trucks during my resto. Forgot most of it since then.
Originally Posted by bigreed91
Awesome thread, i feel like if you were making videos while doing all this its something id watch on saturday on horse power tv lol.
I was thinking if I got a painless or American wire harness the problem would solve itself with the extra wires lol
And thanks just wanted to make sure the aluminum wasn't compromised or anything weird that I'd regret later for not noticing
Originally Posted by JessyJ
Yup 1 wire for the electric chock.
You should be able to put a heli coil in that cover.
#98
#99
Made some progress with some 60° weather today! Got the rust off the water pump, did a quick paint job, decided to paint the fan, alt bracket and pulley while it was off. Drilled out and installed the the helicoil... much easier than I was expecting. Let's hope it holds up! Just need to order some gaskets (water pump, fuel pump, timing cover, and front main seal) and then I can start reassembling. Oh and while looking for ways to clean my timing cover off, a buddy on the f150forum (where I'm at for my 10th gen) mentioned dry ice blasting... never heard of it but we have 2 shops in town that do it so I'm going to call and get some quotes tomorrow. Here are some progress pics
#100
Here is your 1 wire elec choke power point according to mikeo0o0o0.
#101
Edit* discovered the timing cover is a one size fits all for older engines so some engines had a smaller pointer used on it. I'll attach that pic too in case anyone else has this question in the future
So noob question.. why do I have a threaded hole behind my timing mark?
Also if the timing cover was bare aluminum from factory; what color was the timing mark? Mine is steel so it needs to be painted... currently painting it the silver of my water pump and thermostat housing
#102
#103
#105
When I replaced my water pump I couldn't ever find the lower radiator spring for sale so I said screw it and didn't put it back in... well since I'm here again I figured I'd look for the part again. Finally found it from national parts depot! $5 so I'm going to buy it and toss it in... That's cheap insurance if you ask me.
Also found my old one to make sure the sizes were the same... (I have a box where I just throw everything in that I take off the truck.) looks like it's actually smaller than what NPD shows going in my truck (old = 1.5" OD and new = 1.625" OD) But I'm sure bigger is always better lol my hose ID is 2" so either way I'm good.
