Fordguy2100's Hoosier build thread
#46
#48
Originally Posted by grinnergetter
Your cat is a bad *** for sure. That green tractor brings back some miserable memories. My dad was quite enamored with green tractors with flywheels hanging off the side. Learned to drive on a 330.
I'll check that green highboy for d shafts too.
Grabbed the dang flashlight and checked. Everything you need is on that green truck. Everything.
#49
Got the dipstick tube reinstalled in the oil pan, hopefully getting some time this weekend to get the oil pan installed then I'll fire her back up and make sure all my leaks are gone... well minus the major bendix steering assist leak that probably isn't going away any time soon. Finding Driveshafts and Rust repair are still on the schedule thru this winter
#51
#52
#54
Originally Posted by meangreen92
Nice truck, and cool thread! Those wheels are going to look good on there.
Yes they are going to look good.
Originally Posted by SlikWillie
I would clean them with Superior Aluminum Brightener from Oreilly's. A gallon cost $11 and your wheels will literally look brand new. Just follow the directions.
#55
#56
My local oreillys didn't carry that stuff but Napa did. Picked up a gallon and was quite impressed with it. I'm going to need to put some elbow grease in to make these look perfect but for just spraying with the acid and then hose, stuff worked great!
Edit* I had them in nice before/after comparisons but for someone reason the mobile app doesn't upload them in the order I choose
#58
#59
I think the rim to steering knuckle issue is because you have a D44 closed knuckle, low pinion, Bendex steering set up axle. Primarily because a closed knuckle axle is different than a open knuckle axle. I am pretty much guessing at this point.
Like I said over the phone, I will work it get them back and give you a full refund.
Rim to rim they can match the 16", but 16" tires will NOT fit for sure. Outside edge to outside edge measurement will be off, because 16.5 have a extra bead of some sort.
#60
