Dually tire pressures
Does anyone have an explanation to why the recommended tire pressures in a dually the fronts are 75psi and the rears 60psi? With a payload figure of 4995 I would think you'd want more pressure in those rears too. I know it's spread over 4 tires but still curious.
Any thoughts, opinions, all knowing answers?
My dually states 75psi front & 60psi rear also. I run 75psi all around.
I would say they recommend 75psi front & 60psi rear for best ride & drive quality, the 75 in the front for the weight of the engine (running 60 may result in wishy-washy steering), the 60 in the rear for a smoother ride (running 75 in the rear will result in a rougher ride), this is because the weight is spread over four tires instead of two.
SD Dually
SD Dually
Calamity Cowboy
05-26-2013 07:58 PM
