1969 F250 Ranger Camper Special
Hey guys. Friend had this 69 F250 Ranger Camper Special sitting in his yard and said I could have it if I got it out of there. Looked it over and its in great shape body and interior, and even frame etc. Has a 360 auto, motor needs rebuild, tranny too. The paint has patina and is shot, but there are no dents, all the chrome and reflectors and markings are all there, and in mint shape, not one scratch. The bed and tailgate are also mint, in fact the paint in the bed is better than the truck. No dents at all in bed. All glass is good, doors close smooth and nice, and the interior is mint except for the carpet. Floor is mint. It even has a sears air conditioner right in the middle, what a beast. Lol. I took it because it looks like an easy project, but to be honest. I havn't a clue what I should do with it. I saw that the chrome alone on the internet is huge bucks, so it has a lot of value as it sits. Apparently the bed and tailgate are tough to get too. Not sure if I should do a stock rebuild, low hot rod, 4x4 bad boy, or just sell it for some good cash, or part it out???? Are these things worth anything to restore. Its a darn cool looking truck, kinda thinking of doing it up in some fashion. I'm a bit of a diesel guy and expert. I like building those trucks. This would be a first if I did it. What do you guys think. What would you do with it?
Motor sat with valve covers off, but hood on. So its rusty looking, but complete, and no its not running. Good rebuilder though if I wanted. Tranny is there, don't have a clue what it is or if its good. Motor and tranny were working when he parked it, but now, who knows. IF, I did something with them, I would completely rebuild anyway. The rest of the truck is no crap mint. Except paint is totally oxidized, and rust is starting but I can rub it off with my hand. Not one dent scratch or hole anywere, and all the chrome, reflectors, grill, interior panels and bench are all in fantastic shape. Chrome just needs waxing, no blemishes at all. I would still remove all and restore everything right down to metal. Just not sure if It worth it. I know the diesel motors I make, and the trucks I do are worth lots, but whats an old ford worth??? See these tv shows doing nice builds, never see a ford on there?? Why is that? Its a cool looking truck, as I stated, I have some ideas for it. Just not sure what the best root to take is. Usually stock is the best bang for your buck, but I'm more fun than that. Need some Ideas. Hit me guys, what would you do with it?
Yup, kinda the way I was leaning. Although I have all the 4x4 stuff sitting in my shop if I went that way. But I feel it has more value stock looking and modern power plant and running gear. Lowered, and ya, two tone.
Ok, been doing some research on my options with this truck. Need some input. Guy that gave it to me said he was going with all modern inside, vintage outside, like most seem to be directing me too. He told me that I can buy a 2004 or newer Crown Victoria, and with little fabrication its a darn near bolt in engine, tranny, complete disc brake and suspension, and rear axle, disc brakes etc. So basically the entire modern running gear and motor, for anywhere from 1500 to 5000 bucks. Is this true??? If it is I'm thinking an ex cop car with all the hot chip and stuff they did to them??? THis would be the deciding factor since its so cost effective! If its true.
Bumpsides aren't worth much on the market - too plentiful, not really all that old. BUT... if you like the truck and enjoy driving it it has worth beyond its market value.
It sounds like it just needs paint and a fresh engine and you're cruising. Seems like a no-brainer for an experienced mechanic like you.
CV swap on a 250? Nah. Just drive the thing and enjoy it for what it is.
Bumpside is the nickname for the fifth gen F series trucks (1967-1972).
Yes, that's a tool box. They come in handy.
Others with more experience will know more about the feasibility of a CV swap in a 250 (chassis cross section is larger), but even on a 100 there is some cutting and welding involved. There are several CV build threads and one involving a Mustang on this forum you could check out to get an idea of what's what.
https://www.ford-trucks.com/forums/1...-vic-swap.html
https://www.ford-trucks.com/forums/1...ld-thread.html
Ok, thanks for the links. The CV is a fit with some fab work. But nothing too extensive. SO front end and motor are covered. What would you recommend for the rear set up? Going to keep leafs since the fab work to change is real extensive as noted in the mustang conversion.
I didn't realize there was much difference between the 2 wheel or 4 wheel drive. I thought axle and transmission would be the main difference, the rest looked pretty easy to transfer over with some welding. About the same as the CV swap as far as fab work from what I saw. But if the frame is different, that's a different story. Meaning the 2 wheel is built less stout than the 4 wheel, which seems pretty retarted to me. Why would they do that??? My 350 4 wheel is the same as the 2 wheel except the axle tranny set up. SO why did ford make two frames??? Any way, the 4x4 is only considered because its basically free since its just sitting there, and its a bad propane vehicle. Any other route and I have to blow some cash on donor vehicles. SO that's the only reason. Also, its a 460, so it would be like parking a semi truck in my car port if you know what I mean. Could it handle that motor?
