7.3/SAS swap. (Converting to a 4x4) - Ford Truck Enthusiasts Forums
Old 02-29-2016, 10:13 PM
Gooz
Gooz is offline
Gooz is starting off with a positive reputation.
I have a 92 Ford F-250 Custom with a 5.8W 5speed 2WD. How difficult would it be to swap the 5.8 with a 7.3 and convert it to a 4x4 solid axle? Is it even worth it?
Old 02-29-2016, 10:44 PM
Nothing Special's Avatar
Nothing Special
Nothing Special is offline
Nothing Special is a name known to allNothing Special is a name known to allNothing Special is a name known to allNothing Special is a name known to allNothing Special is a name known to allNothing Special is a name known to all
I'd say it's probably not worth it. Either conversion (2WD to 4WD or gas to diesel) is probably borderline, and you should have a pretty good reason to do it that way rather than get a new truck. With both needing to be changed? Go out and get a diesel 4WD.
Old 03-01-2016, 08:30 AM
tjc transport's Avatar
tjc transport
tjc transport is online now
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
agreed. the cost to convert will be about the same or a little higher than if you were to find a decent diesel 4X4 after you source all the parts.
you will need frame modification. spring mounts. front cross member modifications. different front springs. larger radiator and radiator support. different electrical system, both in cab and in engine compartment. diesel engine. diesel trans. transfer case. transfer case mount. different trans/transfer case cross member. modified fuel lines. modified fuel tanks.
Kingkong0192
01-27-2017 05:26 AM
Wellbucket
1999 to 2016 Super Duty
01-10-2017 09:21 PM
bigcrunch
12-31-2016 09:28 PM
Austin87-460
03-24-2016 09:04 PM
Austin87-460
02-16-2016 10:58 AM
Quick Reply: 7.3/SAS swap. (Converting to a 4x4)
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
