Ignition lock Actuator blues - Ford Truck Enthusiasts Forums
Old 02-29-2016, 10:49 AM
juna106
juna106 is offline
juna106 is starting off with a positive reputation.
Hi there
I know there's an old thread about this issue, but I was watching this tutorial
But mine is different. It doesn't just "flop out". I've gotten to the point where I have unscrewed the turn signal switch and unscrewed the assembly, but I can't get it out so that I can remove the steering column housing and get at the actuator rod.
Plus, I'm in that maddening place where tiny pieces are falling out that I am now having to remember where they will need to go.
Suggestions?
Old 02-29-2016, 06:12 PM
badaz4570
badaz4570 is offline
badaz4570 is gaining momentum as a positive member of FTE.
I put a starter button on my dash. Mine would turn on but wouldn't crank. Just be careful it's in park.
Old 02-29-2016, 08:15 PM
Lead Head
Lead Head is offline
Lead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to all
Well if you've removed all the screws holding it in, it's probably just stuck, right?
Old 02-29-2016, 08:51 PM
justcruzin125
justcruzin125 is offline
justcruzin125 is gaining momentum as a positive member of FTE.
You need to pull the turn signal cam out. ( the white object). Pull the lock cylinder out, and also the housing with the shift lever. Then it will pull out. Its a tight fit. I did it a couple months ago
My4Fordtrucks's Avatar
My4Fordtrucks
My4Fordtrucks is online now
My4Fordtrucks is gaining momentum as a positive member of FTE.My4Fordtrucks is gaining momentum as a positive member of FTE.
The turn signal assembly is most likely hung up on the turn signal switch wiring. The plug/connector is down the column by the ignition switch. Unplug it and then you can pull the switch up and out of the way.
Old 02-29-2016, 09:04 PM
88n94
88n94 is offline
88n94 is gaining momentum as a positive member of FTE.88n94 is gaining momentum as a positive member of FTE.
There is a good write up on the procedure on here. Do a search. It's quite a procedure, I could never have done it without a write up.
RenoHuskerDu
02-11-2018 10:13 PM
Dannym
1968-2013 Full Size Vans
19
07-11-2017 08:31 PM
laextreme5
15
02-28-2017 11:28 PM
BuckHunter1960
05-22-2016 04:47 PM
cadudite
04-13-2016 12:58 AM
Quick Reply: Ignition lock Actuator blues
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
