Are 2wd dually spindles the same length as a SRW?
From what I can find nline SUSPENSION COMPONENTS for 2000 Ford F-350 Super Duty
Ford only lists 1 pair of spindles for 2wd super duty's.
Will you have to upgrade the rearend to handle extra tire load?
They are not the same. A dually has a spindle length of around 5 5/8" to 5 11/16". The other size is about 4 3/4", though this one I have only found on a couple cab and chasiss trucks. (BTW, those 2 different sizes use different wheel seals. The short dually spindle uses the same seal as the SRW) The SRW spindles are 3 9/16" to 3 5/8". All of them do use the same bearings, races, and spindle nut though, unless you had something special ordered from the factory.
I have found this to apply to all 99 to 07 Super Duty f250 and F350 trucks. There are a few oddballs out there though.
Thanks for the info. I bought the ambulance. I didn't know what the gear ratio was till I opened it up.. I have a fleet of the same units at work and they were all 3:73. Mines 4:10...... Witch I do not want.. So now I'm contemplating buying dually adapters... Any input on thesis adapters??
Sherman Manley
04-14-2019 10:18 AM
