6.0 no start
6.0 no start
06 6.0 F250 throwing code P0677 #7 glow plug circuit module. I don't think one bad plug would cause a no start, however coupled with too much oil possibly? Swapped my oil about 500 miles ago, I put in 20qts accidentally, drained off about 3-4 qts eyeballed, truck fired up and ran fine no smoke nothing. Yesterday morning I was leaving work and moved my truck from parking space to behind the bay at my fire station, I turned the engine off. Loaded up my gear and turned the engine to the aux position and someone was talking to me so inlet it sit for a while in the auxiliary position. Went to crank no start, turned the key off then back on and it fired. Fast forward after 7 different starts throughout the day, I'm at dinner with my son we go to leave engine will not start at all, rolls and rolls and rolls nothing. Towed her home and scratching my head. Over filled oil with a bad plug cause no start??
MODS: egr delete, new oil cooler, cat and muffler delete, upgraded Y turbo pipe. Also have an SCII throwing codes p0677 and p0401 egr code
Any help, thank you
Any help, thank you
you may have fried the FICM relay or caused it pain.
Any live data reading device, like a Scan Gauge II or Torque Pro on your phone?
Pull the ICP connector, its on the passenger valve cover. Try that first. Then replace the FICM relay, drivers side near the hood hinge. Both the relays are the same, you could swap them to see what comes.
P0677 won't prevent a start, might be a little rough initially, until it fires a few times. P0401 is an EGR code, probably because your running a deleted EGR. Just make sure it's plugged into the connector, it helps control the fan speed.
Pulling the ICP plug will override any low oil pressure issues that may be caused by a failing High Pressure Oil Pump (HPOP) that may be lurking.
ok so here's what I found. Replacing the #7 glow plug was merely a 16$ dollar rule out. So I get the plug installed and she fires right up. I run around town do a few errands and notice as the engine temperature rises the idle gets more erratic. Had lunch with my wife told her I want to drain off a gallon of oil that was over filled. Drained off about 1.5 gallons to put the oil a little below the max line. I drive around to get the eng temp up, get the water temp to 173 and eot to 175 and as I'm driving the truck just shuts down. Luckily I was in my neighborhood, the wife towed me home. Called a few buddies 2 to be exact, they had the exact same issue, it's a high pressure oil leak, at least it was for them. I did notice on the passenger side under the vehicle along the frame, and a few of the hoses that were under there, they were all wet with fresh oil, not actively dripping but wet like it was freshly dripped. Towed her to the lot across the street from the house and will drive my other vehicle until I can get to it. Out of town until next Sunday. Ill post an update as they come.
Start with the bold stuff. Then pull the IPR and see if the screen is damaged, if so, replace the screen. Still a no start, get prepared to air test the truck to find the leak... my bet is a dummy plug let go or the STC fitting.
@watsonr yes I do have a scanguageII no code except for the p0401 which is the egr. I was getting the p0677 then swapped the glow plug and fixed that. It will only cold start, my dad actually started the truck this morning and moved it into my driveway, it only has the no start issue when it is hot. I will investigate the swapping of the relays when I get home. I'll get it hot and try to recreate and swap those and see what I come up with. Makes sense, I think I'm losing pressure somewhere and the 6.0's have that fail safe to shut down upon low or no oil pressure. Thanks so much for your help I will definitely look at all possibilities. Thanks again!!
Doubt it is your HPOP, rarely go bad in 05 and up but nothing is out of the question. As Randy said likely the STC or dummy plugs...maybe stand pipes.
You have the resources you need right here
tech folder is full of great info... you need to read this one on no-start condition.
https://www.ford-trucks.com/forums/8...condition.html
Welcome to the site. Lots of guys willing to help with info and even show up to pull a wrench or a beer top with you.
Where you from?
Where you from?
Where you from?
Where you from?
Port St. Lucie, Fl.
Thanks for all the help, haven't had a chance to pull the icp, I did talk with a ford mechanic that's a friend of a friend, he thinks it's either the ipr, a dummy plug, or stc. Getting it towed to him on monday. And it hasn't fired since my last post. Pops moved it to my driveway and it won't start at all now, just rolls and rolls. I'll try and pull the icp this weekend. If I pull the icp and it starts what does that mean? I'll let y'all know how it goes. Thanks so much again.
Pulled the ICP still no start, I could only read 2 of the values you told me to look for. I don't have a computer based scan gauge, just the one the plugs into the OBD2 port. I was able to get a FMP reading of 48 and the ICP reading said 1414 but I think thats wrong because it was unplugged. All the other scans were not able to be read do to the limits of my gauge. Perhaps there are some after market code I can install on my gauge but I was running on short time. I'll have it towed on Monday and let y'all know what the mechanic says. Thanks again for your help!!
PS I also did notice, the oil pressure gauge in the truck never moved, I think after a couple seconds it should register pressure no? I checked this with the ICP plugged and unplugged. So, my thinking is I am not getting any oil pressure at all.
Thanks mustang_309
I did a youtube search and found some great info, a ford tech named Robert I think walked through a whole host of tests. Here's what I found.
SYC-1
FMP-48.0
ICP-25
IPR-84.7
Now if I'm understand these readings correctly, number one I'm not getting the required 500 psi to start correct, and the IPR is working entirely too hard at almost 85% when just cranking. Possibly trying to over compensate for the lack of pressure? Now what does all this mean? Bad ICP, a leak, bad IPR, ?? I'm thinking it means i've got a leak somewhere and the pressure is not building to acceptable limits, in a nut shell. Any help thanks
SYC-1
FMP-48.0
ICP-25
IPR-84.7
Still haven't heard back from my mechanic yet, had the truck towed to him on Tuesday, said he'd have something for me by Wednesday, yesterday. I don't know if thats a good thing or a bad thing that I haven't heard, either he hasn't got to it yet or he is finding more and more issues??? I'll let y'all know what I find.
