E99 PCM Control Unit VCQ4 & Torque Pro?
I am looking at getting a tune and decided to pull my PCM to see what kind it was and on my E99 it turns out I have VCQ4. I was expecting to see an XLE4. Is there anything I should know about this?
I also have been working with Torque Pro all day and cannot get any of the PID's in Tugly's post to work, but did get the already installed PID's to work. Just can't do any of the custom ones like BARO, MAP, TFT, EBPV. I know I am entering them correctly. Could it be this PCM? Does any one with an E99 having trouble with the same PID's?
Here is a link with quick info on that PCM.
Ford PCM F81F-12A650-DF information
Here is a pic of my PCM number.
Sometimes when I was having problems setting up Torque I would have to completely disconnect the device (Android phone) and shut down TP and then restart it again after shutting down the truck and restarting it.
I managed to get all of the PID's working, but had some typo errors and connection issues at first.
on
Cody is correct. No one was doubting him any way..
Here is the corresponding line from my PCM list:
1999 VCQ4 9DTA-BEE DPC-412 F81F-DF 7.3L F-250/350 DIESEL - AUTO CAL COLD WTR VHAE9E2
The reason for my post.....: What is the difference between this DPC-412, a DPC-402, and a DPC-422?
I had not heard of it being compatible with the e99 either.
Details not withstanding, there is a lot going on in each one you listed that won't work correctly in an interchange situation although a 402 can be used in place of a 412 all day long.
