I posted having a noise in my transmission a while back thought I would give a update.The mechanic finally heard the noise.They changed out the main control valve in the transmission. Said they had some issues on the 2014 model trucks. Something about the pressure plate and fluid. I believe he said there was a TBS
on this issues. Hope this help other members.Thanks for the feedback on my first post.
2014 crewcab lariat 4x4. Here is the question. This is only when I'm backing
it up and only after putting truck back in drive do I get the steering wheel whine. It sounds as if it is low on fluid. Only last for a seconds or two. Could this be the start of a steering problem or possibly a brake issue? Just throwing
this out there. Any suggestions would be great.
Reason: put my first post with it
