2016 f250 lariat edition changing steering wheel to a heated one any help
I just bought a new 2016 lariat edition black truck the only thing its missing is the heated steering wheel that the platinum has can I just buy a new wheel or will the truck have to have an upgrade in radio or computer any help please
Main reason I went with the Platinum was because I didn't want chrome bumpers and grill.
But oddly enough they delete chrome in some places, and add it in others - tow hooks, mirror caps, door handles, etc.
Back on topic, the steering wheel is activated on the MyFord Touch screen. I dont think there is any other way/switch to activate it. Same with the seats. MFT screen only. No hard switch.
I dont know if the dealer can reflash the MFT screen (if you have it) to include the steering wheel switch.
I take it they have an element or pad in the wheel to heat it. They are not complicated.(unless Ford decided to complicate it) You could probably wire it into an upfitter switch to turn it on and off but you have use the right wires in the connector. This is assuming Ford didn't put a thermocouple and other crap in to control the heat output tied into the MyFord system or some other module. However considering how much of a PITA it can be to ad something as simple as Fog lights on these trucks I would not assume it is simple and going to be easy.
Click on "Private Meesages" under you name in the upper right corner of your compute screen. Then at the left of the screen you will see "Edit Avatar" in your Control panel. You can link an avatar or upload it from your computer. You are limited to a small file size with an avatar so pictures have to be sized small.
