97 F350 4x4 Regular Cab steering issue after new tires, balljoints & alignment ???
Lets note I have had good and bad experiences at NTB...Good at their salem NH store, Bad at the now defunct Greensburg IN store.
I had a bad experience at the firestone stone here in Cincinnati OH.
So far the local Tire discounters has been good.
One trend I am noticing is that the hack jobs behind the desk (service writers) often know nothing about auto mechanics... or at least very little.
I generally like to talk to the mechanic if possible, Tire discounters is nice as I can generally hang outside the bay watch him work and ask questions to engage him and get solid answers/ opinions...
This asking questions is what caused the issues with Firestone...
With my free floating rear end there is a special socket to release the ratcheting nut that holds the bearings and drums on....their mechanic said he uses a chisel to pound that nut off...essentially destroying it.... yeah...none of my vehicles have gone back there..
If you're doing tie rods, before you take anything apart take a measurement of the drag link assembly and wheel to wheel bar assembly. I usually go from the center of the grease zerk on the tie rod end to the center of grease zerk on the opposing side. Write down the measurements and assemble the new parts, adjust them in or out until you hit the magic number.
My trick for this is to buy new sleeves along with the tie rods / drag links / etc., then completely assemble it off the truck. Then drop the whole old assembly at once and set them side-by-side, along with measuring them. Then hang the whole new assembly. If the wheels haven't turned (truck on the ground) in the interim, it should line up good.
Yes, I've heard that Moog quality isn't what it used to be. Wish I'd heard that before I bought and installed the ball joints... They looked good and the machine work seemed OK.
Probably too late and I'm not sure it will help much at this point; if it were mine I'd also have them loosen and properly torque the ball joint nuts per Moog's written instructions.
Like I mentioned in the other post, I'm not sure if it will help to re-torque now. Plus, the symptom of improperly torqued ball joints is tight steering so if your truck is steering OK now that they fixed the toe-in, they were probably torqued close enough. Here's a link. The torque instructions are near the end of the second page.
http://fme-cat.com/livedocs/DYK12_101_ENG-R.pdf
Also, I understand that most alignment shops will give you a computer printout of your before and after alignment specs? Seems like they should provide that so you know what they did and what your caster/camber/toe-in settings are?
kc 300EX
11-13-2010 10:56 AM
Bayer-Z28
15
05-07-2010 09:47 PM
KTM Mike
07-22-2007 03:25 PM
