motor and tranny mounts
Yes, you can replace the engine and trans mounts without removing the engine and trans.
Loosen the mount, raise the engine or trans, out with the old mount, in with the new and tighten everything.
Be sure to find a secure place to lift or jack from and be sure to secure the engine or trans while you are replacing the mounts, so they can't fall and crush anything, like your hands. I can't stress this enough. Work safely.
Be careful and watch as you raise things. Make sure the you have adequate clearances and you aren't putting things in a bind. Be especially watchful of fan to shroud or radiator clearances and of radiator hoses and trans cooler lines.
Good luck.
Good luck.
1955effie
07-03-2005 02:54 PM
